Very confusing O2 sensors
Old Oct 10, 2021 | 01:02 AM
Kial's Avatar
Default Very confusing O2 sensors
Hey so I’ve got a weird situation on my Ls1 swap landcruiser when I connected my volt metre to my 4 wire O2 sensors. The plug sat on the manifold and was looking a little bit worse for wear so I replaced it but when I was checking the voltage I was getting 4-5v on 2 out of the 4 wires to the O2 sensor on both sensors. This is on the ECU side of the plug not from the sensor. The other 2 wires are reading nothing.
The car ran fine but I thought I’d have one wire with 5v for the heater and the others would be ground and a sensor wire?
Are these even o2 sensors or are they a 4 wire wide band or something?
I’m a bit confused
thanks
Old Oct 10, 2021 | 07:11 PM
99Ls1fever's Avatar
Are you using an aftermarket harness or an old stock GM harness?
I would take a volt meter and touch each end of the wires and make sure they are making a complete circuit.
New harness, I would check connections just to make sure they aren't caked with grease and the terminal isn't making a good connection.
Old Stock Harness, a lot of heat cycles on those wires could be melted inside cracked or just lost integrity being on the bottom of vehicles for almost 20 years.
Either way I would volt meter test each end of the wires to make sure you are getting a complete circuit. This way you can narrow down your problem to which wires aren't making a good circuit.
