Stock 411 ECM Compensate
The PCM os is 12212156 if that helps Everything else is stock intake, injectors, TB, front dual bank NB 02's, exhaust manifolds, fuel pressure reg, MAF, dual knock sensors ect.
Will the stock tune with VATS removed run the engine with rite fuel timing and knock retard until the rings seat and parts are settled and be drivable in preparation of 7875 turbo "I have" Im literally rebuild the starter clean up the harness prime oil and FIRE.
No funds currently for HPtuners megaquirt speeduino
Sorry about the quick and dirty post, I spend about an hour with part numbers and more detailed specs and forum decided to log me out and lose my post. If more details need I can try my best to answer them.
