Knock Sensor
Old Jan 24, 2022 | 06:29 PM
vht's Avatar
vht
Default Knock Sensor
Does the Terminator X use the knock sensor to retard timing? I guess I should say, can it be set up to use it and if so, can you drill and tap the block to use the Gen IV sensor? This will be a boosted 5.3 and it occurred to me that I'd never heard of anyone using the knock sensor as a safety so to speak but also this stuff is all new to me, Terminator X and tuning in general, so I thought I'd ask.
Old Jan 25, 2022 | 12:12 AM
QwkTrip's Avatar
Yes, but it has to be wired for the type of knock sensor you have. Holley wiring diagrams will show you the wiring scheme for each type.
Here's a teaser video that shows you the menu where you can change knock sensor settings in software. I'm sure there are much better videos, this is just the first that came up in a Google search for me.
Old Jan 27, 2022 | 04:25 PM
vht's Avatar
vht
Thanks Qwktrip.
Old Jan 27, 2022 | 08:52 PM
theunderlord's Avatar
FWIW, I would zero all of the knock sensors out and not worry about it. They're meant for OE ECU calibration.
Old Jan 27, 2022 | 09:39 PM
Originally Posted by theunderlord
FWIW, they're meant for OE ECU calibration.
No, they're meant to remove advance when preignition happens. NOT just for calibration...
Old Jan 27, 2022 | 09:41 PM
my mistake! got my wires crossed there somewhere.
