generic wideband
Old Mar 9, 2022 | 04:54 AM
95maroz28's Avatar
Default generic wideband
im know i asked this before but does this wideband appear to be similiar to the aem? The part numbers are the same
Amazon.com: CNPAPC 30-4110 UEGO Air/Fuel Ratio Gauge AFR 52mm with 4.9 LSU Sensor, WideBand A/F Ratio UEGO O2 Controller Gauge Kit : Automotive Amazon.com: CNPAPC 30-4110 UEGO Air/Fuel Ratio Gauge AFR 52mm with 4.9 LSU Sensor, WideBand A/F Ratio UEGO O2 Controller Gauge Kit : Automotive
Old Mar 9, 2022 | 10:44 PM
NSFW's Avatar
The AEM gauge is only about half as deep, and the connectors are different.
AEM also has a canbus output, whereas this only has 0-5v output.
It's a shitty imitation from a shitting company that's poaching AEM's keywords in order to confuse people who search for the real thing. **** those guys.
Old Mar 9, 2022 | 11:21 PM
theunderlord's Avatar
Also, support speed shops that have people that can answer questions about all this stuff, buying **** from amazon sucks.
Old Mar 10, 2022 | 10:32 AM
LilJayV10's Avatar
Hardly anyone does that anymore. They want everything CHEAP. Then run to the internet asking for free help and tunes when their **** doesn't run right.
At least in my experience.
Old Mar 11, 2022 | 06:00 PM
95maroz28's Avatar
100$ is pretty good and what id expect to pay for a wideband as it it it includes a 50$ o2 sensor. So this isnt a good gauge? It looks like it may work or function as good as the aem? I really like the way glowshift looks but their o2 sensor is only a 30 day warranty if it was a 1 year warranty id probably purchase it. MSD also has a wideband gauge for 260$ if it was down around just under 200$ id probably purchase it. So has anyone used the innvote lc2? Im looking for a wideband to confirm my afr is correct when WOT. I dont want to spend too much the old aem is 160$ from amazon but i think the innovate looks better digital gauge numbers big reading. Innovate also has a dual wideband for 313$ but another tuner for ls told me it would read fine if you just install it on one side should be the same unless you have injector issues. Id prefer the dual wideband but its hard to confirm as as they have it 12.3 and 12.8 so its hard to confirm if the gauge is even accurate lol just by looking at it. I do need to purchase one pretty soon.
Old Mar 11, 2022 | 10:16 PM
NSFW's Avatar
The actual AEM 30-4110 is $170ish.
AEM 30-0300 is $185ish and it has RS232 and Canbus outputs for data logging. I have two, they seem like good products.
