HP Tuners: Target Lambda (Engine-Fuel-Temp Control)
Old Mar 10, 2022 | 06:32 PM
FCar2000TA's Avatar
Veteran: Air Force
Default HP Tuners: Target Lambda (Engine-Fuel-Temp Control)
Poking around in my tune, I saw Target Lambda in Engine > Fuel > Temperature Control > Component Protection. I would think that you would want this to be 1. But since it is under "Component Protection", is there a reason that it would be set higher than 1?
Old Mar 11, 2022 | 12:54 AM
smokeshow's Avatar
Enrichment
Old Mar 11, 2022 | 07:16 AM
FCar2000TA's Avatar
Veteran: Air Force
Originally Posted by smokeshow
Enrichment
Does that get negated by dialing in the MAF and VE table?
Old Mar 11, 2022 | 08:51 AM
smokeshow's Avatar
No. There are several thermal models that estimate temperatures. If the catalyst for example gets above a certain temp threshold it will begin enrichment based on those component protection cals. Multiplies fuel mass just like PE.
Old Mar 11, 2022 | 09:21 AM
FCar2000TA's Avatar
Veteran: Air Force
Ok. I will set them back to what they were. Thanks!
