6.2 idle quality w/cam
I realize this is highly subjective, but I believe my L94 with a BTR Stage 2 LS3 cam idles pretty bad at 13" of vac at about 800. Car shakes pretty bad, but runs and drives excellent otherwise. I read all these threads about how people with much bigger cams use the word "mild" but I can't see how that is possible. I moved the timing and AFR all around and not much changes. I had a professional assist, not much different. Is this about it, or is this something about the BTR cams that makes them a little rougher?
Combo - L94, BTR Stage 2 225/238 .620/605 113 lsa 113+3, LS3 intake/DBW TB/injectors, headers/Holley TermX/TH400/
Thanks
Thanks
I would say what you are experiencing is normal for that amount of overlap. Ime anything with positive overlap will chop.
Here is a 224/228 112 in my old LS1 car w/ 850 idle.
https://www.youtube.com/watch?v=8wgKAPy5VkQ
55-56 in neutral, 59-60 in gear at 800-850. 75kpa that motor must be ready to jump out from under the hood lol
Sounds great - and rowdy. I guess any positive overlap will allow exhaust to back up into the intake. So should I insist on a cam with no more that 0 overlap???
Thinking about swapping in an Ls9, Ls3 or maybe the cam motion stg 1 Ls3 cam which is 212/222 116. Do you guys think the cammotion cam will make a lot more power than the factory cams? Thank you.
