assuming check gauges doesnt throw codes?
Old Mar 28, 2022 | 06:49 PM
Floorman279's Avatar
Default assuming check gauges doesnt throw codes?
on my 2000 camaro, i know that check gauges doesnt really throwing a code, but with a tech 2 does that make diagnosing this easier? all my gauges are working normal and withink proper ranges
Old Mar 29, 2022 | 01:08 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Is the light on constantly, or does it flicker or sometimes go away? If it's constant regardless of what the gauges read, have you tried a battery disconnect to see if it resets the light?
I've never tried scanning for this, so I can't answer that part of your question.
Old Mar 29, 2022 | 07:15 PM
no havent tried battery disconnect. i did swap clusters and same thing. its solid and has been on since it first showed up
Old Mar 30, 2022 | 09:41 AM
cobra30689's Avatar
The Tech 2 might help. You can access the cluster to do gauge sweeps and what not.
Old Mar 31, 2022 | 05:09 PM
LilJayV10's Avatar
I'm confused about what the actual problem is.
Old Mar 31, 2022 | 06:41 PM
check gauges light on cluster despite all my gauges within range
