E40 flex fuel ?
Old May 6, 2022 | 12:11 PM
jimmyg's Avatar
Default E40 flex fuel ?
My buddy bought a c6 on e85
Wants to flex fuel it since he lives in mass .
Can't find anyone willing to touch it . Something about the e4o ecm being a pain in the *** .
I have an e38 I can give him , but finding someone in mass who can do it seems the biggest problem . It's an ls2 stroker with an F1a
Did 800/718 on 13 lbs . Was advertised as an 1100rwp monster . Somebody along the line turned it down . He would like to turn it back up
And flex fuel it so he can drive it to the track .
Old May 8, 2022 | 12:20 PM
Pulse_GTO's Avatar
It would be a MAJOR ordeal to change the ECM to an E38 from an E40. I've worked on plenty of E40 ECMs. They suck with larger injectors, but other than that, not really a pain to work with once the tune is scaled. It does take someone that knows how to properly scale a tune for larger injectors in order for everything to work the way it should.
Flex Fuel is really easy to add. All you friend needs to do is add a wire to Pin 4 on connector C3, plumb and wire in the alcohol sensor, turn the FF switch on in the tune and populate the tables necessary.
Old May 8, 2022 | 03:16 PM
LilJayV10's Avatar
Yes I've done it. You have to add the wire at the PCM for the FF sensor.
The E40's are a bitch to deal with when you start making big power.
