MAF vs SD
Can you explain this setting? I find no info online about it's effect.
I see .1016 is common in a truck file......
This will be interesting to experiment with.
My Corvette already has that number in it, and does the same thing.
Could be an argument for SD tunes being the way to go.
I’m a little puzzled why I’m the only guy noticing this?
A lot can be solved on the fuel to wall impact factor. Make small adjustments to the high MAP areas to solve lean tip in, and conversely, make small adjustments to the low map areas to solve rich tip outs.
The VE table is also where the PCM looks during rapid transitions, so having a good VE map is key to smooth revs. Your problem sounds like a transient issue in addition to the MAF filtering smokeshow so eloquently described. I’d try multiplying the 100 row on the fuel to wall impact table by 1.1 and blending it down to the 50 row.
That table is all about prediction, and since the MAF is essentially “behind” all the time, adding some predicted fuel on fast revs should help.
The VE tables on both cars are untuned. So I’ll do that on the Olds.
My corvette has the dual VE tables. I have an 02 file ready for it, just haven’t done it yet.
Constantly learning is what it’s all about. You and I share that “pickiness” when tuning, which opens up rabbit holes of learning opportunities.
In all honesty I don’t know if fuel transients will fix your issue completely, but logically thinking, they would play a big part in it. It’s just that those tables are often overlooked or misunderstood.
In physics, when vacuum increases (aka RPM rate in your case) fuel evaporation increases. So it’s logical to think when you are spooling faster, fuel is atomizing faster, therefore requiring more fuel in the calculation. That formula bugged me for quite some time trying to figure out how much pulse is a result of the transient tables. I never did solve it because you can’t use a user math to reference another user math so the formula got too complicated for the software, thus ending my progress on that.
Sure would be cool if we could do that @HPTuners. Just a humble suggestion.
I seriously wonder at this point how the op feels about this post at this point considering he asked a “simple” question lol. Not so simple as he rightly pointed out. At this point this thread has been straight hijacked lol. I’ve seen no reply’s or questions so far. He just dropped a bomb and dipped out. Good for him. @imaswfan
The difference is all of us are actual tuners, and “overlog” the **** out of our cars. When I do a customer car, I get it to run right, test it to try to work out the bugs, take my time and get it back to them when I’m satisfied. That’s my “full tune” package when going into it. Difference is on my own car, I’m almost literally never satisfied lol. If I see a number outside 5% anywhere on my tables I’m suddenly concerned.
I’ve made a **** ton of folks happy with their cars, but I’m never happy with mine for some reason lol. If I took the gauges out and stopped logging stuff I’d have no idea. But for some reason I don’t on my toys, but hey, it drives me to learn new things so I can’t be mad about that.
The best example perhaps is our glorious OP, who asked a complex question, involving many factors, and has yet to grace us again with his decision. He’s actually thinking he can get 550 whp out of what he has with stated planned mods. He must be assuming someone can “tune in” about another 200 bhp to get him there or something because I don’t see it. Just to go over 500 I had to stroke mine to 427 and get my compression near 12:1 N/A. Good luck OP. That costs money. Lots of it.
It’s almost like much of this information is free and even explained on YouTube and this very forum, and even this thread, but yet folks still don’t take the time to research it. They just want it now. If I was less honest I would be one of those tooners you are talking about because some of these folks might actually deserve to be taken to the bank. Call me crazy, but I think I just described a portion of the current tuner market.
Im also not saying everyone needs to learn how to tune, but modifying your car and doing literally zero research into the impact of the parts (after researching the parts) makes no sense to me. You should at least know what you want when you show up for a tune.
I will say we tune opposite of each other. I always, always always tune the VE table first. If the car won't run I just hack on the VE till I can get heading in the right direction. I think it's a quirk of mine because of how mad I was when I found out how garbage my tune looked when this all started in LS stuff.
Probably the best money I spent, honestly, getting screwed by that "tuner"
I thought about making a youtube video. Even got about halfway through recording one, going through all the physics of idle control before I decided it was ****
