Rough idle and no accelerator above idle
Old Jun 14, 2022 | 03:51 PM
Ls1typhoon's Avatar
Default Rough idle and no accelerator above idle
I have a 93 Typhoon with a 97 Corvette LS1 engine (drive by wire). It was running just fine until it wasn't started for a couple of months. The idle is rough and doesn't sound like it is running on all 8 cylinders. I assumed the gas was bad so I added 3-4 gallons of premium. It seemed to idle a little better but I have no accelerator response, it will only idle. I did an OBD scan and it consistently throws codes:
P1120
P1125
P1220
P1281
P1516
Since P1120 indicates that the TPS is out of range, I replaced it. This made no difference.
I thought about replacing the APP sensor in the accelerator pedal assembly but instead of replacing parts that may or may not make a difference I want to diagnose the problem to find the cause.
Any suggestions?
Thanks
Old Jun 15, 2022 | 08:04 AM
pcguy's Avatar
Might help if we new what you found on the other codes???
Nick
Old Jun 15, 2022 | 08:48 PM
rpturbo's Avatar
Did you have E85 in it? Does it sound like it's missing?
Old Jun 16, 2022 | 08:28 AM
dlandsvZ28's Avatar
https://www.corvetteforum.com/forums...on-sensor.html
https://autoservicecosts.com/obd2-codes/p1516/
Old Jun 16, 2022 | 09:52 AM
Ls1typhoon's Avatar
After it idles for a few minutes, it starts sounding like it's missing - not running on all 8. I don't think the gas is E85, at least I didn't notice that...
Shell premium.
