Anyone here using a DashLogic and a PLX AFR module together >
Old Jul 3, 2022 | 06:34 AM
Tin Indian's Avatar
Default Anyone here using a DashLogic and a PLX AFR module together >
I have a question for any of you folks that are monitoring your engines AFR by using a DashLogic controller along with a PLX wideband AFR module.
When my engine is idling, the AFR reads about 2.53 or thereabouts ... Should be reading about 14.7
Any ideas as to what is wrong ?
________________________________
Here is the formula I have set in the Dashlogic for reading AFR with a PLX SM-AFR wideband module:
And here is what I have set in the 'Advanced Mode PID Edit" for what will be displayed on the car's DIC:
Old Jul 3, 2022 | 06:36 AM
Tin Indian's Avatar
BTW ... My DashLogic and the PLX SM-AFR module are all properly wired up together.
Everything else that I monitor (Boost, Timing, LTFT, etc) all read correctly .... It's just the AFR that is way out of wack reading around 2.45 - 2.55 or thereabouts during idle (should be reading about 14.7)
Old Jul 3, 2022 | 08:23 AM
Tin Indian's Avatar
BTW ... Come to find out that I was using the wrong display PID.
Got it working fine now.
