Ls swap fuse block questions???
1.I have thick purple wire called the “s” wire from the starter that leads to the oem fuse block.I’ve read it goes to the neutral saftey switch to the ignition but I have no idea what to do with it. Do I hook it up with the pcm ignition,the ignition 12v???
2.I also have a blue and a pink wire from the tac, do I hook both of these to the 12v ignition or do I add another fuse??
3.what all do I hook up to the 12 ignition?? I have the o2s,tranny, some grey and green wires coming from the neutral saftey switch, a/c. Do all these go to 12v ignition? Do I have to plug all sensor to this 12v ignition? Because I have some running to the gbcm and I’m keeping it.Also the gbcm has two red/white stripe wires where do I hook these up?
im keeping it a stock ls swap stock trans and motor
