Microsquirt to LS1 wiring help needed
"To use the WLED and ALED as ignition outputs, you would move the DIP switches for 1 & 2 to the enabled position. You would enable the crank pullup resistor if using a hall effect or optical sensor, but not if using a VR sensor.
To fire the coils, you will use IGN1, IGN2, WLED and ALED. The ignition outputs fire in that order as well, so you will pair the coils to match up with the firing order. For a LS firing order of 1-8-7-2-6-5-4-3, you would pair 1-6, 8-5, 7-4, and 3-2. That gives you this firing order with the pairings
IGN1 - 1-6
IGN2 - 8-5
WLED - 7-4
ALED - 3-2
