Lean and boggy ls1
Old Aug 4, 2022 | 08:36 PM
Blakney555's Avatar
Default Lean and boggy ls1
Ls1, 114lsa comp cam and supporting mods. Installed and tuned last December. Last weekend after a 40 minute cruise it barely started and the wide band said it was lean, any throttle kills it but after awhile will rev up but not snap up to a higher rpm like normal. New to the cam game. No check engine lights and no weird sounds or smells. I’m at a loss….
Old Aug 5, 2022 | 12:37 AM
Check all connections and grounds... THOROUGHLY.
Old Aug 7, 2022 | 08:31 AM
Old Buzzard's Avatar
A couple ideas..
1. Try the diagnostic/tune forum for possibly more responses.
2. Take a data log and tune file with you when you go there.
Old Aug 7, 2022 | 08:54 AM
Utinator's Avatar
Maybe the MAF is bad or dirty.
Old Aug 7, 2022 | 12:16 PM
Blakney555's Avatar
Default Fixed
Correct on the maf, pulled it apart (no screen) and there was something laying across the sensors, fell out before I could grab it but running like a tip again. Thanks fellas
