Terminator X Max?
Old Aug 28, 2022 | 07:29 AM
Old Buzzard's Avatar
Question Terminator X Max?
Am attempting a bench test of a new system. Powered up and attempting a tps reset, I get a "code 19" on the handheld.
I've done considerable searching and have found no lists for numbered codes.
About 20 "views" on the Holley forum and zero replies.
NE1 have a location, explanation?
Old Aug 28, 2022 | 08:47 AM
VETTRK's Avatar
Watching closely
have same system..
Old Aug 28, 2022 | 07:58 PM
toomany's Avatar
I recently had the same code pop up on the initial power up of my Terminator.
What worked for me was skipping the Tps learn and going straight to setting up the base settings in the wizard. In there it give the option on type of throttle. DBC or DBW. Once I selected DBW and completed the initial settings I was able to do a TPS relearn without issue.
The directions aren't the best and the hand held prompts you to do a relearn right away. I assumed I did something wrong or had the wrong parts.
Old Aug 29, 2022 | 05:55 AM
I got that code on the first power up. Haven't seen it since.
I'll try your idea and report back.
Thanks!
Old Aug 31, 2022 | 09:16 AM
Cool Like a charm!
I used your workaround, made a "for instance" tune, hit the TPS reset and it works perfectly.
I have the main power to a batt, the red/wh wire on a toggle sw to replicate the key sw. the loose black wire to ground.
No sensors were used. The cyl head grounds were not in play.
A tip for easier handheld input. Use the stylus! {I have a ballpoint pen with a soft tip, that I use.}
Thanks for the help!
