Holley custom igntion set up
Old Sep 15, 2022 | 04:45 PM
truckdoug's Avatar
Default Holley custom igntion set up
Hey yall. I'm messing around with ignition dwell on my turbo car. In order to enable the dwell table in the terminator v2 software you must select "custom" and then whichever your crank and cam sensor you are using. in my case 24x and single pulse. Then it prompts you to select sensor type. I am unsure whether to use digital rising, digital falling or magnetic.
I'd like to hear from someone familiar with the custom ign configuration
Thanks
Old Sep 15, 2022 | 04:51 PM
truckdoug's Avatar
well it took me 3 minutes to find it in the training manual. page 42.
2 wire sensors are magnetic
Old Sep 16, 2022 | 01:30 PM
minytrker's Avatar
Once you select custom ignition the motor will have to spin over longer before starting. I have made 1,000 plus at the wheels with stock coils and stock dwell settings on countless cars. You can also use an advanced table and add dwell under boost and leave ignition settings stock.
Old Sep 16, 2022 | 10:07 PM
truckdoug's Avatar
heh just fired the car and noticed it takes a sec longer. thanks for that heads up.
i was messing with the inductive delay just now and set at the minimum it drops 3 degrees of timing by 5500 rpm. I added 50msec and it seemed to stabilize
have you seen anything like that?
Old Sep 17, 2022 | 05:42 PM
minytrker's Avatar
Yeah I have 40msec in several vehicles
Old Sep 17, 2022 | 06:59 PM
rpturbo's Avatar
Sounds like you're ready to light the fire in that thing Doug! Hit it hard, hit it fast, get it in before your off the glue.
Old Sep 18, 2022 | 12:34 AM
truckdoug's Avatar
thats the plan! get my 9 out of it before I sell it
