Dropping cylinders at idle
What is static fuel pressure ? No mechanical gauge, but should be 58psi with corvette style return filter/fuel pressure regulator
What fuel pressure at idle ? See above
Can you approximate camshaft duration figure ? I don’t know but sounds stock, possibly ls7 or similar mild cam
Where did you obtain Injector data ? No access to tune yet so idk what data was input for injectors
