13 silverado ecm ?
Old Nov 19, 2022 | 08:08 AM
69PrimedC10's Avatar
Default 13 silverado ecm ?
Ok so I picked up a 13 silverado that had a fire under the hood. I replaced all the wiring under the hood and dash and found a used ecm out of a similar truck. Ecm numbers are the same. Will I have to get the ecm flashed and re-programmed? Thanks in advance! Tim
Old Nov 19, 2022 | 04:03 PM
B52bombardier1's Avatar
Did the original ECM get too much fire damage? But yes, the new one will at least need the same engine and transmission programmed in and VATS defeated. I'm not sure but the Body Control Module, the Transmission Control Module and the Fuel Pump Module - all if equipped - may need some kind of re-tune treatment. Somebody sharp with HP Tuners on newer vehicles than I'm familiar with can answer these questions better for you.
Rick
Old Nov 21, 2022 | 08:05 AM
The original got too much damage to use.
Old Nov 21, 2022 | 10:04 AM
minytrker's Avatar
It will be best to get it flashed with correct calibration and the VIN programmed correctly for everything to work. The VATS will keep it from running just plugging it in.
Old Nov 21, 2022 | 11:19 AM
Ok thanks, appreciate the help
