E Rod 6.2 issues
Old Dec 3, 2022 | 05:42 PM
slinginrods's Avatar
Default E Rod 6.2 issues
Just finished an erod swap into a 72 c10. Startup is good after the initial flare and it settles down to base idle. I have roughly 550 rpm and surge. Maf is installed per gm instuctions. All grounds are secure and clean. Throttle response is ok with idle hanging a second or two after blipping the throttle. I have not performed crank variation yet. Could this help with the idle issues? Also intermittently has a 2-3 second run after key is switched off. The ignition wire is connected to ign term on fuse panel. When it continues to run ther is 0 volts at the ign run wire. Any ideas are appreciated
Old Dec 3, 2022 | 09:28 PM
Cooter!'s Avatar
I have an E-rod 6.2 that idles at 550. I thought it was too low but everything else seems ok?
Old Dec 4, 2022 | 01:50 AM
RonSSNova's Avatar
What HP rating?
The 480/490 version has been known to surge.
Old Dec 5, 2022 | 12:54 PM
LilJayV10's Avatar
What HP rating?
Didn't some versions have an issue where you couldn't lower the idle speed below 900 or something or am I thinking of something else?
Old Dec 6, 2022 | 12:13 AM
RonSSNova's Avatar
Yes, same tune file.
We fixed the surging by putting a honeycomb in front of the MAF.
Old Dec 6, 2022 | 09:58 PM
So I was able to get a scanner on it. Has some maf codes and it actually went into limp mode. I’ll dig deeper tomorrow. I just remember the throttle body has been swapped out with a professional products one.
