hunting idle
where would you start?
i corrected iac effective area and desired air flow to stock (there was not much difference). it didnt surge on start up but that might have been just coincidence, cant drive it now. what else? im looking at everything where drive is different from p/n like learned air flow correction, engine speed compensation (multipier is the same) or rpm set point adjust. direct air flow correction is the same, learned drive limits are the same. stall saver is the same (100 rpm lower) but is zeroed out in original tune.
cracker is the same as in original tune, throttle follower airflow is doubled.
what else?
i dont really want anybody to loose time looking at hundred parameters and maybe even comparing them to an original tune. perhaps somebody has an idea off the bat?
