Backfires and loss of power
Old Jan 12, 2023 | 04:39 PM
MrAgentRaptor's Avatar
Default Backfires and loss of power
I think it’s a sensor that has gone bad but I have now replaced my coil packs and my cam sensor and the loss of power on now seems more noticeable. I’m slowly running out of idea of what could be causing this.
Old Jan 12, 2023 | 05:49 PM
Cam sensor would not cause the problem. The crank sensor would be a possibility.
Old Jan 13, 2023 | 02:05 AM
ChopperDoc's Avatar
If you can scan it, see what the knock sensors are doing. If one has crapped out and is reporting knock, it will pull spark and result in a serious loss of power.
If that’s not it you might have a clogged cat, if you have them, but it will behave as you are describing. Tough to say based on so very little information, but either of my guesses are founded and possible and hopefully get you pointed in the right direction.
Old Jan 13, 2023 | 07:03 AM
B52bombardier1's Avatar
Can you post a tune and logs with the vehicle running?
Rick
