Any scanners with tech 2 capability ?
Old Feb 8, 2023 | 07:13 PM
sjsingle1's Avatar
Default Any scanners with tech 2 capability ?
I need more than a 100$ handheld can do ...I was looking to get a matco scanner but cant get a clear answer if it has full tech 2 capabilities....does anybody know exactly what all functions the tech 2 does over cheap handhelds ? I hate to spend the $$$$ on matco and only get half tech 2 capabilities....or would i be better off with a china tech2 or even spring for a real one off ebay ?
Old Feb 9, 2023 | 10:48 AM
NicD's Avatar
7 Second Club
There is no scanner that can do what a Tech 2 can do, that being said some scanners do have some of the features that a Tech 2 has but without knowing exactly what you are after nobody can say for sure.
Old Apr 2, 2023 | 10:54 PM
aprilsfool's Avatar
Well for around $100 you can get the functionality of the tech 2, you can get tis2000, tech2, and gds. there is no scanner other than the tech 2 that has full tech2 capabilities. im not sure what your trying to do. if your just working on gm then its a simple google search away. its important to know the tech 2 is a 16 bit os. so to be able to get all the good out of it, get a old 32bit xp windows laptop. if your working on a span of different models and makes just get the snap on.
