NFG trying my hand at Programming
Old Feb 9, 2023 | 10:57 PM
475hp 5.3's Avatar
Smile NFG trying my hand at Programming
I'm Marty. I have a 2006 Silverado 1500 4x4 that I am putting an LH6 in. I was a mechanic and body tech/painter for a # of years at AJ's Customs in AZ. Have always been able to tune carbureted cars. Currently have a 1935 ford Model 48 original 221 Flt Head V-8 and a 1938 Chevy 2-door Business Coupe with original inline 6. Thought I would try my hand at tuning. Have PC hammer 🛠 , Tuner Pro, and bought the MPVI3 from HPTuners. ECU Serv#:12602802 Hdw#: 12589162. I tried my making my own XDF file to turn off Vehicle Anti Theft. Since I am replacing my L59/LM7 with an ATK-built 475hp 5.3 LH6. Yes the AFM and DOD components have been physically replaced on the engine. I thought everything was all good. Found HexDec point to start building XDF. Pretty sure I messed up one of my tables as my truck will not start. I have spent easily 500 hrs educating myself on how exactly to decrypt my .BIN file and make an.XDF file. Apparently, I did not do it right. lol If anyone can point me in the right direction or knows of a BIN decoder. I've read that the XDF for 2004 OS 12587603 is a universal donor, but unable to register to Gearhead-EFI. If anyone has a copy of that XDF? I would be forever grateful. Thank you.
Old Feb 10, 2023 | 06:37 AM
LS1Formulation's Avatar
Post up in the PCM/Diagnostics section, you'll have more luck there.
Old Feb 14, 2023 | 01:21 PM
clay68c10's Avatar
I would use universal patcher. No XDF needed for it, and it can make a TunerPro XDF if you wan to go that route.
Old Feb 23, 2023 | 02:06 PM
475hp 5.3's Avatar
THank you. The universal patcher worked perfectly
