Best place to send PCM for the 4L80E segment flash?
Old Feb 16, 2023 | 11:17 PM
PITT M3 RR's Avatar
Default Best place to send PCM for the 4L80E segment flash?
Where’s the best place to send my pcm to be flashed for LS1 with 4L80E, cable throttle and no security stuff active? It’s a 2002 Camaro Red/Blue PCM. Engines from the same car. Trans is from an 05 Sierra 2500
Set up is going into a 69 Camaro. I’m in Pittsburgh pa, thanks.
Old Feb 17, 2023 | 08:21 AM
minytrker's Avatar
I can do it .
Old Feb 17, 2023 | 12:44 PM
PITT M3 RR's Avatar
Originally Posted by minytrker
I can do it .
can you send me a contact #?
Old Feb 17, 2023 | 02:07 PM
Click on the LSX Power Tuning link near the bottom of his post
Old Mar 10, 2023 | 01:43 PM
Kawabuggy's Avatar
OP, do you have HP tuners? If so, just post your tune, and we can do the segment swap here and send you back the updated file that you can burn in... Or...if you don't have HPT, you can ship your PCM out to someone who has the ability to bench flash the PCM (I do! But I'm in Houston, TX) who can then perform the segment swap on the PCM and ship it back to you. If you were close, I'd do it for FREE.. I have unlimited licenses on my interface for most of the early year 411 PCM's and I'm set up for bench flashing.
