95 trans am won’t scan
Old Feb 26, 2023 | 08:43 AM
Kmullins's Avatar
Default 95 trans am won’t scan
I have a 95 trans am. I know I need an obd2 scanner that reads obd1 codes. I have one and it comes up with a can’t read error. I’ve taken it to auto zone and oreillys both places get the same thing. It has set for a long time. I was able to scan it before I parked it. The car runs but check engine light comes on when it gets warm.
Old Feb 27, 2023 | 07:52 AM
wssix99's Avatar
Save the manuals!
Did you check your OBD fuse?
Old Feb 27, 2023 | 01:34 PM
Kmullins's Avatar
I didn’t check the fuse. I assumed it was ok because I had 12v on the plug when I checked it with a multimeter.
Old Feb 28, 2023 | 04:28 PM
wssix99's Avatar
Save the manuals!
Check your PCM BATT fuse. (While you are at it, also the PCM IGN fuse - but I expect the car would not run well without that one.) I believe the OBD II connector will give you battery voltage even if your PCM is dead: https://fuse-box.info/pontiac/pontia...ses-and-relays
