PCM Question
Old Mar 13, 2023 | 07:19 PM
Noah alyssa's Avatar
Default PCM Question
does anyone know how much the dealership would charge to "flash" my ecu to an automatic one, i currently have a six speed ecu.
Old Mar 13, 2023 | 08:00 PM
01CamaroSSTx's Avatar
Best advice would be to call a tuner and get them to help you with this. I just pulled a stock tune file with HP Tuners from an ECU that came out of an 02 Z28 with automatic transmission in order to get a start up tune for my 99 Camaro build. The car originally came with a V6 and the tuner did not want to use the V6 ECU to write a tune for the V8 for some reason. My guess is that it saves time working with one from a V8 car but he will have to disable the VATS in order for the ECU to work in my car.
Old Mar 13, 2023 | 10:52 PM
Carkhz's Avatar
They'll probably charge one billed hour of shop labor, since that seems to be typical for module programming. In reality, it only takes about 10-15 minutes of real time once they're plugged in and going. I did essentially the same thing for myself when I needed a manual transmission OS for my LS4 swap into my Monte Carlo. I only had to pay the $45 access to license a Vin in Techline Connect to do my own programming at home. If you own or have access to a J2534 pass through device, you can do the same as I did. I just picked applicable VIN when I needed an OS that matched.
Old Mar 18, 2023 | 11:49 PM
Bbknucks's Avatar
If you have access to a vci then could just edit your tune yourself with pcmhammer/tunerpro?
Old Mar 19, 2023 | 03:22 PM
LS1Formulation's Avatar
Notice the OP is BANNED. A scammer.
Old Mar 19, 2023 | 04:58 PM
Bbknucks's Avatar
Oh.. . I thought that was like a status or something that people gave themselves
Old Mar 19, 2023 | 09:21 PM
Well they weren't when I originally posted.
Old Mar 20, 2023 | 07:15 AM
Lol, yeah... I figured that. I just didn't want people to waste time contributing to dead threads, especially when the OPs only purpose in posting was to get their count up so they could scam people.
 Michael S. Palmer
Old Mar 20, 2023 | 08:46 AM
True that!
