Help! Can an E67 VIN be programmed into an E40 ECU?
Now, my issue is: I need the 2008 E67 VIN rewritten into the 2007 E40 ECU so that I can pass emissions inspections, etc. I've had my local tuner try with HPTuners and we thought it was successful after he licensed it, did the CASE relearn, and it was reading the 2008 VIN on HPT but I plugged in another scanner and it was still reading as the 2007 VIN (for some reason with the digits not in order). I also had another guy that uses Tech2 try but he said it would trip the security system if the VINs don't match between the other modules. He didn't actually try rewriting it because he was afraid the truck wouldn't start if he did, and said if he rewrote the 2008 VIN to all the 2007 modules some functions may not work?
Is it possible for the 08 E67 VIN to be programmed to the 07 E40 ECU or am I in a bind? Thanks for reading and any helpful/knowledgeable comments
