Tune copying from E67 to E38?
Old Apr 5, 2023 | 11:15 PM
sixt9er's Avatar
Default Tune copying from E67 to E38?
I had a mail order tune done on a E67 ecu. It was crappy. Started the vehicle and it runs for about 10 minutes then dies. Running waaay too rich. Towed the vehicle to a dyno-tuner. It was base-tuned because the hydraulic throw-out bearing failed. Took vehicle home, replaced the throw-out bearing and tested it on the street. Vehicle runs very well. During testing, the harness got burned, severely. I have a spare E38 ECU, with a stock tune and a E38 stand alone harness. I want to have the base tune from the E67 put onto the E38 so that I can get the car back to the dyno. Is it possible to have that done? Can anyone recommend a tuner that can handle the task? Vehicle is a 69 Camaro, with a cammed LS2 and Magnum T56. Im out in Cali, if that matters. Thanks for your help.
Old Apr 5, 2023 | 11:38 PM
Duplicate post....
Old Apr 6, 2023 | 08:57 AM
minytrker's Avatar
We can hand copy most of it over but depending on what OS and year each ECM are there could be a lot of tables that wont copy and then it will still need to be tuned in the end. It would be better to just get the E38 tuned IMO.
