Ect -39
Old Apr 28, 2023 | 04:32 PM
epfatboy's Avatar
Default Ect -39
We have a 03-07 P59 ECM (Blue/Green) and we can't get the ECT's to register, it keeps registering -39. Both the harness and sensor are known good, we swapped the sensor to a test mule and validate the ECT harness (Blue 74/Blue 80) had continuity and pins were in good shape.
The ECM went thru a same OS segment swap, everything else seems good, truck starts/runs good, won't start when warm and can't get fans to kick.
What are we missing???
Old Apr 28, 2023 | 05:21 PM
v1.5's Avatar
Can you verify that the ECM is providing voltage to the sensor? If you have a back probe, put it on the signal wire and see if the voltage is within 0.5-4 and decreasing with increasing temp.
Old Apr 28, 2023 | 08:26 PM
epfatboy's Avatar
BLK wire has 5 volt measured at sender connector.
would jumping BLK to the YEL (signal) put ECT at the top of the temp range?
Note:
Blue 80 is the BLK wire
Blue 74 is the YEL wire
Old Apr 28, 2023 | 09:16 PM
v1.5's Avatar
Note:
I don’t believe the ECT would read at all if the wires were shorted; the ECM probably has a failsafe for that and will just throw a code. You could bypass the sensor and connect the wires together with a resistor in between of at least 200 ohms. That should put you in the upper end of the range
Old Apr 30, 2023 | 06:49 AM
epfatboy's Avatar
False alarm!
ECM had 2 bent pins in pos 80 and 40. Bent them back and she’s reading fine now.
Old May 1, 2023 | 04:36 PM
mrvedit's Avatar
Moderator
Thanks for giving us the update. I think it best to close the thread.
