High idle
Old Apr 28, 2023 | 09:22 PM
startingstock's Avatar
Default High idle
Need help hith terminatorx. I've had holley hp in the past and am not completely green. My issue is I have to open the throttle blades quite a bit to get it to start. One I het it to temp and try to slowly close the throttle blades to bring down the idle(iac is at 0 because of how open throttlebody is) it starts struggling. I try to add timing to help it, but after taking a brief datalog, it's only showing 16 degrees actual advance, but I'm commanding 20. I figure it's the idle spark pulling timing to lower the idle. But I need the timing to stay in so I can close the throttle blades a little. Any help would be appreciated. Cam is 240 on the intake duration. 429 cubic inches.
