0411 swap O2 sensors issue
Old Jul 12, 2023 | 12:38 PM
Tyler Dietzenbach's Avatar
Based upon my research, the injector bank select is the problem. If it's not matched properly to the actual setup, the fuel trims will eventually go full positive on one side and negative on the other in closed loop.
The firing order table is simply for troubleshooting a misfire on a specific cylinder , so obviously we will change that as well.
Old Jul 12, 2023 | 09:52 PM
benflynn's Avatar
awesome, glad this was figured out
Old Jul 12, 2023 | 09:56 PM
benflynn's Avatar
Pin those o2 backwards and it will work tonight and swapp it back when u fix the tune.
Old Jul 12, 2023 | 10:42 PM
I would do that if i had the capability. My tuner will be taking care of this Sunday when he gets back to the state. Open loop runs well about 99% of time time, pretty fat though.
Old Jul 13, 2023 | 10:18 AM
NicD's Avatar
7 Second Club
So you believe that adjusting the tables you showed me above will take care of it? Anything else you've seeing? Car made 560hp and it runs really great.
I mean there are so many tables that have been changed for no reason from what a stock 2002 f-body has I would be starting over with a known good stock file. Lots of those table changes look like just copies from another OS and that never works out right and always causes a problem of some sorts. Deka 60s certainly don't have a 1.16 msec offset at 13.0V, it's using the boost enrichment table which can have delays, one knock sensor fitted, PRNDL enabled, this looks like a ton of tables were just copied out of a truck OS. Yeah, I would be starting over for sure.
Old Jul 13, 2023 | 10:22 AM
That's correct. The first tuner grabbed a truck pcm, that's how all this started. My tuner and I have gone through and already fixed quite a few things. Tune related and also wiring related.
If the o2 sensors work after this, I'm going to call it good. The car runs amazing and strong otherwise with a very safe AFR.
Old Jul 13, 2023 | 06:31 PM
Would you mind elaborating on the deka 60s and how they should be? Could you also discuss the boost enrichment table and what delays mean?
With my tuner out of the state, and me being slated to pick up HPT in the future, I'd like to know more about these things right now. The PRNDL enabled doesn't appear to make any difference. 1,2, D, OD all seems fine.
Old Jul 16, 2023 | 11:33 PM
Met with tuner today. We got the injector bank select corrected as well as a couple other things.
O2 sensors worked perfectly immediately after adjusting the injectors.
SOLVED!
