5.3 into LS1 TA
Old Jul 13, 2023 | 10:04 AM
st1's Avatar
st1
Default 5.3 into LS1 TA
What all needs changed besides intake? Will it run right with stock ecm, or do I need to swap ecm matched to engine? I'd prefer to avoid tuning. Not concerned with making power, but want it to run right. Any help appreciated.
Old Jul 13, 2023 | 10:38 AM
benflynn's Avatar
Prob run, diff heads, diff bore means timing certainly will be off. MAF table will be off. Use the ls1 intake and inj and it will run, fueling will be off a bit bit closed loop will reign it in. Chop the timing map over and tune MAF would be my minimum off top of my head.
Tuning is not as hard as it seems at first.
Old Jul 13, 2023 | 11:20 AM
st1's Avatar
st1
More a matter of $$. Why not just run the 5.3 ecm and injectors if that's a concern?
Old Jul 13, 2023 | 11:41 AM
Only if the ECM that came with the engine is the same type that's in the car the engine's going into
Old Jul 13, 2023 | 01:19 PM
st1's Avatar
st1
What do you mean by type? Would get one physically the same, black/red plugs. Shouldn't have to be same model number or part number.
Old Jul 13, 2023 | 01:26 PM
Both the LM7 and LS1 use the "Warren" PCM. You might be in luck here.
Do you have the PCM the 5.3 used in its original vehicle? It should interchange
Old Jul 13, 2023 | 02:52 PM
st1's Avatar
st1
Do you have the PCM the 5.3 used in its original vehicle? I should interchange
Yes. That is what I was thinking of. So just intake, oil pan?
Old Jul 13, 2023 | 06:24 PM
Just swap the LS1 parts over that will allow the 5.3 to fit in your car and you're good to go
