LS3 ECM Broken Pin
Old Aug 10, 2023 | 11:23 AM
Mikes64's Avatar
Default LS3 ECM Broken Pin
I'm helping a friend with with a GM LS3 Connect and Cruise swap for a 37 Chevy coupe. This build has been through a couple shops before landing at the current shop. Its at the point where we tried starting this week with no success, so with no way to check with a laptop we decided to look for anything obvious. It will eventually be taken to a local tuner for a Check. The most obvious thing we found were two pins broken in the Grey port on the ECM pins 28 & 29.My question is can this be repaired or should we start looking for a replacement? If it can be repaired, anyone have a link to someone? Thanks for any help.
Old Aug 10, 2023 | 11:50 AM
minytrker's Avatar
Its not worth repairing IMO, Id replace it.
