IAC cleaning?
Old Aug 12, 2023 | 02:44 PM
Z28JLR's Avatar
Default IAC cleaning?
When you disconnect and remove the IAC valve to clean it, when you reinstall it do you have to do any sort of recalibration/relearn procedure?
I know the TPS you have to I believe, but do you have to do anything when you remove the IAC only?
Thanks!
Old Aug 12, 2023 | 02:57 PM
Any calibration for the IAC should be for a clean one, so if anything, a clean IAC should be better matched to the ECM than the dirty one.
IF the ECM did adapt to a dirty IAC, it will relearn to the clean one the same way. Might take a little driving time....
Old Aug 12, 2023 | 03:11 PM
Z28JLR's Avatar
Makes since, I appreciate it. Thank you!
Old Aug 12, 2023 | 08:41 PM
slothman's Avatar
disconnect the battery for 10 minutes. the computer will relearn everything in about 100-200 miles. that should be done periodically anyway. and it's a good time to clean the terminals and other wires. and test battery voltage
