LS1 misfire
in the fall I was driving the car to where I store it and it was running terrible, horrible miss to the point it would hardly run.
so this spring I got it out and pulled the map sensor to find some moisture on it, I replaced the sensor and it runs better but still has a pretty bad miss in the low end.
it was originally throwing a map code but is no longer showing any codes. If I run it at wot it will miss till it hits about 1800 rpm’s , then it cleans up and runs fine.
I pulled the plugs for inspection, they look a little fouled but no smoking gun here..
has anyone dealt with a similar issue?
any help would be appreciated!!!
tia,
Scott
You might just be getting a P0300 DTC, but you can look at the misfire counter and see also.
You use a temp gun and check to see which header tubes are colder than the others.
