SD tune on a 98 Camaro SS auto problems?
I first got it back it was supposed to be tuned for maf. The tuner is said to have good knowledge of the 98 pcm.
It had surge and idle issues. The shop retuned it. Unknown to me it was tuned SD.
I was told by another person that 98's with an SD tune will kill a 4L60E.
After all the work and tuning, the trans lasted 700 ish miles with 2 track passes. The shop warrantied the transmission with a different core. It kasted 300 ish miles.
Your 4L60E uses the MAF sensor signal to control line pressure inside the transmission. Without that MAF signal being available to the PCM it's going to be difficult to keep the trans from burning up the 3rd and 4th clutch pack.
Don't forget that even with a "built" trans, you WILL STILL need to match the gears in the rear differential to your tire size-think higher numeric gears to give the transmission a chance at survival. You will also need to match the stall speed of the torque converter to the cam-and also to give the engine a chance to rev and increase transmission pump speed which will help build pressure and volume to again, help keep the transmission alive. You will also need a BIG external cooler. The factory trans cooler inside the engine radiator is barely suited for an all stock transmission. If you have done anything to increase horsepower, or torque, or added a higher stall converter, it is mandatory that you install a BIG external cooler to deal with the extra heat. Lastly... the tune... It is life or death for the transmission. Even if you get everything else in the "system" set up correctly, a tune that is not 1000% right is going to fry the transmission. No way around it. I'd say you have a $5000 repair bill ahead of you to get everything set up correctly and have a complete "system". If you don't have the money to do it RIGHT.. how will you find the money to do it TWICE, or three times, or......? $5000 might be a low estimate.. but hopefully you get the point.
Good luck with your project.
The other core did not come from the trans shop.
Yes I have a large external oil cooler for the trans.
Yes it has a stall, cam, heads and gears.
The trans was warrantied because the shop that did the r&r also handled the tuning. So as to why they warrantied it wasn't on me. I didn't deal with them.
So yeah I'm out the money for all the work done you think it's the tune?
I'm just trying to figure out why it happened.
Now if you had HP Tuners we would ask to see both the tune and a log of things like MAP, TPS and most importantly the transmission's PCS current.
The MAP and TPS should be enough for the PCM to determine the load and reflect this by lowering the PCS current to increase line pressure.
