L96 issue *stuck*
throwing these codes -
p0341- CMP sensor
p0326 -knock sensor
p0101-MAF sensor
I have replaced - MAF sensor, Cam sensor, timing chain, guides, crank and cam sprockets, VVT solenoid.
timing is good.
when I go drive it it lacks power and the computer reduces power drastically.
not sure what else I can investigate
You most likely don't have sensor(s) issues since you already replaced them. Hook up a scanner with live data and see if the values reported jive. Like MAF values should be 6.0 grams/second in idle. Do values increase as you give it throttle?
I don't know if you have to do a crank sensor relearn on that engine?
