first test drive with rebuilt motor
Motor specs:
C5R block
Callies dragon slayer 4.0" crank
Comp star rods (made by Callies)
Weseco pistons -8 cc
ETP 225cc heads , ported to 232cc by WCCH 2.12 intake 1,94 exhaust valves, .700" lift valve springs
Cam 255/257 .624/.624 lift on 111 +4
Super Victor intake
105mm TB with custom elbow
Stock rockers
LS7 lifters
ported oil pump
dual roller timing chain
Fuel
255L intank pump
60lb injectors
custom feed/return lines with regulator
Tranny
FLT level 6 with hardened input/output shafts
Yank SS3600 stall
SFI flexplate
Rear
3.55 gears with heavy duty posi unit
Test run is attached
