Canbus network HELP
probed 2 pins on the Vehicle speed sensor which someone mentioned on grrrr8 forum to probe these
brand new ecu programmed to my VIN
no matter what module i unplug my high and low lines go flat but if everything is plugged in correctly its a messy graph
also tried probing pin 6 and 14 on the obd2 and one line was at 5 volts just a flat line an the other was at 0 volts also a flat line.
i need to be steered in the right direction, i am decently informed on CANBUS network but when it comes to diagnostics im not to experienced
ive been in other forums and nobody is helping 😭
https://drive.google.com/file/d/1r_N...ew?usp=sharing
