"Security" light, car won't start...VATS?
I cut the wire to pin 50 on the red PCM connector. I connected it to the speed output wire on the TCM-2600. (when I say "connected" here, I mean that I stripped the wire insulation back and twisted the wires together by hand. I don't want to permanently splice anything until I get everything working.) Now, my car won't start. I get the "Security" light in the dash, and the starter just clicks when I turn the key. I figured the VATS got triggered, so I tried to delete the VATS from the ECM tune. When I tried to flash the VATS delete tune into the ECM, it gave me an error and wouldn't upload. Then, I disconnected the TCM-2600 wire from the pin 50 wire, and reconnected the pin 50 wire back to its self. I still get the Security light and now no clicks from the starter. I can still connect to the ECM and read/log with HPTuners, so I don't think I fried anything. I think the VATS just needs to be reset. The last thing I did was disconnect the battery. I figured I'd let it reset everything before I go any further.
Any ideas of what I did wrong here?
First steps first. Get a good battery and then have someone try to crank it and verify you have 12 V on the purple wire at he starter solenoid. If you do it's starter or cable or battery. If you do not then time to dig deeper and you need a scanner to properly perform diagnostics so you don't waste time and money.
The battery did charge back up. I was driving the car around this morning trying to tune the trans. I kept checking the volts every day, and it's losing about .1 volt per day with no charger or load applied. The starter and ignition relays are pulling about 120 mili volts with everything off. It's not much. I had to remove the starter to swap the trans, so maybe I knocked something loose under there...?
