Crank sensor p0035
The power and ground circuits provide the needed power to the sensor.
As the engine spins and the reluctor passes in front of the sensor, what the CKP "sees" is communicated through the sensor/signal wire to the PCM.
That's the wire that is actually telling the PCM the engine RPM.
