PCM Engine Identifier Change Question
Appreciate the help!
While a Gen 4 engine can be made to run in a Gen 3 engine, using a 58x to 24x converter, and dealing with sensor cabling, it doesn't work the other way. It is theoretically impossible to have a 24x to 58x converter for the same reason a low resolution picture cannot be converter into a high resolution picture.
It might be easiest to use the throttle body (TB) from your 4.8. The various TB and ECM combinations with DBW are beyond me. Perhaps someone can recommend the correct 90mm TB for your 5.3.
Same with the MAF, which usually includes the IAT. If you switch to a bigger TB and intake tubes, you will need a different MAF. Aagain, someone else will have to recommend the correct MAF for your new combo.
If you're using a Gen4 motor (58x trigger wheel, etc) then you'll need a Gen4 PCM.
But if you've used PCM Hammer to pull the .bin file from this van... Are you sure it's an 09?
Or have you been using PCM Hammer with a PCM that's on a workbench rather than in the van?
Goal here is to only change the parameters necessary to get the 5.3 to work in the place of the 4.8, Is there an opensource way to do this? I do enjoy working on these but I'm not sure how much I'll use this (gen4 tuning) in the future as I'd likely stick to gen3 or standalone ecus on future projects. So maybe it's more cost and time effective to use HP tuners/EFI Live. I have also found a few places online like Garret Tuning where I could ship it to them for $250ish. So the question I guess is what do you think is the most cost/time effective way to get this done correctly?
