Boost 've table
Old Jun 9, 2024 | 11:18 AM
Gav's Avatar
Gav
Default Boost 've table
Hi,
Boost 've table not going as high as expected, is this a sign of too restricted exhaust? Was expecting figures of like 140 ish at 8 psi
only boosting to 8psi gt45 turbo ls1.
only getting figures like ve 115 in areas and commanding 11.1 and getting 11.1 ish at 7 to 8 psi.
I do have a referenced regulator if that makes a difference?
can definitely feel seat of pants much faster though....
hadn't dynod it though yet.
regards
gav
Old Jun 9, 2024 | 01:36 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Any time your VE seems off, check your fuel injector data. There are several tables that need to be correct, not just IFR.
Old Jun 9, 2024 | 02:43 PM
TrendSetter's Avatar
Ve is ultimately an arbitrary number that means nothing except a relative scaler. Make sure the rest of your config and hardware are correct then the ve table is what the ve table is.
just remember in theory there’s no difference between practice and theory, but in practice there is.
Old Jun 9, 2024 | 10:30 PM
Full Power's Avatar
......... We're in the DEEP end of the pool now.
Old Jun 10, 2024 | 10:41 AM
NicD's Avatar
7 Second Club
Sounds normal to me.
Old Jun 10, 2024 | 02:26 PM
Gav's Avatar
Gav
Ok, just need to get it dyno to see I suppose.
regards
gav
Old Dec 21, 2024 | 04:59 PM
Full Power's Avatar
Hey Gav:
You get 'er Un-Corked yet ?
my 5.3, VSR78/75 with stock truck exhaust made plenty boost 12 PSI, and then fell flat over 4000 rpm.
Found the stock exhaust connector flange was only 2.6" Inside Diameter: I hogged it out to 3 inch, and then went 3.5" pipe all the way back, saw 190 kPa thru 6000 rpm, for a short bit.
Reduced wastegate springs to 10# due to local OCTANE restrictions.
anyway, I learned that the 2.75" OD chevy pipes+muffler are getting restrictive about 400 horsepower.
3 inch single pipe might get you near 500 ( flywheel) HP, but is definitely holding you back.
My best guess is that 3.5" single exhaust pipe starts to throttle your efforts around 600 (flywheel) HP.
Old Dec 22, 2024 | 05:40 AM
Gav's Avatar
Gav
Hi,
interesting to know.
no not yet. Have a problem with drivetrain clunking and problems shifting high rpm.
ended up dropping gearbox and found slave piston very tight on retracting the last 2 to 3mm, hoping that was a cause of my clunking.....but don't know why....put a new one in and seems much better but weather not the right time for high rpm shifting...
bought a 3" cut out normally open with vacuum to close from the bay,
looking to see where I can fit that in the downpipe post wideband which guessing will help my very restrictive exhaust, but not easy to fit in.
regards
gav
 Michael S. Palmer
