Someone explain this startup idle
Old Jul 7, 2024 | 03:57 PM
Tdp378's Avatar
Default Someone explain this startup idle
LM7 5.3 with small cam.
Someone please explain this startup idle. It starts fine and climbs to 1500 or so. After a second or two, it climbs farther to over 2000, why? and then slowly lowers to its resting idle. This seems like a vacuum leak to me but I have smoke tested, brake cleaner tested. Changed intakes, changed TBs and got a new IAC .
This is a cold start but it does is while warm as well although jumps to 3000 before returning to normal idle. The only other thing I can see it a tune issue. Other than this start up idle, it runs fine.
Old Jul 7, 2024 | 06:03 PM
How clean is the throttle body?
Old Jul 7, 2024 | 10:05 PM
SoCalDave's Avatar
Sounds like a tune issue. I don't remember where in HP Tuners you adjust that but if you have a cam one thing you adjust is base running airflow.
Old Jul 8, 2024 | 06:49 PM
LilJayV10's Avatar
post a tune and a log.
Make sure you log STIT, LTIT, startup airflow, IAC desired and actual posistion.
