p0358 code, need help
Old Sep 21, 2024 | 08:08 PM
chrisv45's Avatar
Default p0358 code, need help
Just got my truck running with a p0358 code pending. Running rough, hard to start. I ohmed the coil pack, got a reading of 1.314 (means it's good, yeah?) Got power and ground to the plug. Swapped to a different coil, no change. I don't have a helper at the moment to check if it's actually firing but what else can I check? New spark plug and wires as well. The engine is a gen 3 lq9 swapped into a 97 chevy obs and has been sitting for a couple of years now. Any help will be appreciated, thanks.
Old Sep 23, 2024 | 08:41 AM
dw456post's Avatar
Get a spare spark plug, hook it to the #8 plug wire., ground it, start the truck and see if the plug actually is firing.
