EQ reporting as AFR?
Old Oct 10, 2024 | 11:18 AM
epfatboy's Avatar
Default EQ reporting as AFR?
I put this out in the HPT forum with no luck so I thought I'd try here.
I'd have a AEM 30x AFR guage and it is configured to report thru the HPT Scanner thru my serial port.
Recently I wanted to switch to tracking EQ/Lambda. Instead of adding the new channel I transformed the current channel as I thought this would be what I wanted...
What I ended up with was a Channel configured to report Lambda and it's reporting the AFR instead it even shows a lambda symbol while reporting 14.7...
So I decided to Add the AEM EQ channel directly to the list and it reports AFR
I deleted the AFR/EQ channels and re-added, no dice both report as AFR
I pulled a new Channel config in and added EQ to that, no dice still
I tried a different laptop as well but I unfortunatly (in this case) ninstalled HPT on a shared drive.
Help.. this feels like I'm missing something really stupid and while I hate being stupid I'm outta ideas so here I am.
