P0300 code?
Old Oct 10, 2024 | 08:50 PM
Eric23_Z28's Avatar
Default P0300 code?
So I got a 2000 Camaro z28 with only long tube header and everything else stock it ran fine no issues till recently it started running rough then at times runs fine so I took it to auto parts to use there code scanner it did pop up some 02 sensors code but I figured due to the headers but there was a p0300 code so I checked the spark plugs and seemed fine I also changed the fuel filter ran good for a bit but started running weird again any clues to what it could be?
Old Oct 11, 2024 | 03:14 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
A misfire could be caused by almost anything. However, on any car with headers your first suspect should always be burned plug wires.
Old Oct 13, 2024 | 06:48 AM
EDS01SS's Avatar
If everything else is truly stock then you probably have a vacuum leak somewhere. Also probably why you have o2 sensor codes. out of curiosity, does it start running rough when your foot is on the brake?
Old Oct 13, 2024 | 08:43 PM
Eric23_Z28's Avatar
No when I accelerate and at times when I’m parked sometimes when I start it up it runs rough and other times it starts up and runs fine then starts to run rough also I did change out the fuel filter cause I thought it felt like it was bogging out and it did run good for a bit then started to act up again. I’ll check again to see if I got any leaks anywhere I missed thanks
Old Oct 30, 2024 | 05:38 PM
d_lozy's Avatar
Some guys are able to see which cylinder is misfiring with a code reader, does anyone know what kind of code reader you need to do that? I currently have a Konnwei KW850
Old Oct 30, 2024 | 06:04 PM
Full Power's Avatar
Blue Driver will give per cylinder misfire codes.
