someone that can enable egr for wbo2
Old Nov 18, 2024 | 10:04 PM
K20LEPIPE's Avatar
Default someone that can enable egr for wbo2
hello everyone i have a turbo ls truck that i have been tunning on low boost but i have the egr just showing the 0volts at all times so its been a little hard to fine tune ,can some one please enable my egr so i can log afr ,thanks here is my tune sd 2bar
Old Nov 19, 2024 | 12:11 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
You will have quicker results posting in the thread about this in the gen3 section of the hptuners forum. It requires either an older version of hpt, or doing it with tunerpro. If you do it with tunerpro, you have to use your original 1bar tune file, then convert it back to the 2bar OS.
Old Nov 19, 2024 | 11:42 AM
K20LEPIPE's Avatar
thanks for ur reply gametech ,its a little disheartning that u of all ppl cant help me since i know u take care of a lot of ppl when its possible to do it. i went and looked for other threads about this but they are over a year old since someone asked, and i dont want to bump a old thread ...thanks for your response hopefully someone sees this that can enable it for me
Old Nov 19, 2024 | 01:53 PM
NicD's Avatar
7 Second Club
Here you go, also zeroed out EGR airflow so it doesn't skew anything in the process.
Old Nov 19, 2024 | 02:19 PM
K20LEPIPE's Avatar
thank you good sir , i appreciate u taking time to do this for me ,have a great day!!
Old Nov 19, 2024 | 11:39 PM
gametech's Avatar
The reason I could not do anything with it is that I don't have any of the older versions of hpt in the required range. I have to use tunerpro or universal patcher to enable egr flags. It is usually easy enough to find an xdf that will work with a factory operating system, but none I have found accurately represent an hpt custom operating system. Also, some hpt 3bar operating systems (maybe all, I don't know), actually overwrite the egr flag with something else. I know that does not apply in your case, but something to be aware of if you decide to up the boost in the future.
