Electronics/Holley gurus, is this idea possible?
I have a Terminator X set up in my Firebird, and I added the CAN I/O box so I can add whatever I need to the system. So far, I'm not even using it. I figure this could be a good winter project. The problem is, the Firebird only has switches at the top and bottom of the pedal travel, so there's no way to tell the Holley where the pedal is. The Camaro's clutch pedal position sensor is small and simple, with a 2-pronged lever that lets it ride over a pin so linear movement can be translated into rotational movement. I figured I could make a bracket and mount a Camaro sensor in a way that my Firebird's master cylinder rod could engage the lever. I'd only need to adjust the sensor towards or away from the rod so it would give the full range from 0-5v from top of the travel to the floor.
I'm not an electronics whiz by any means, and I'm only just starting to learn what I can and can't do with my Terminator X system, so any help here would be great. I'm wondering if the sensor could be used as a stand alone, or if I'd need to buy a CTAP to make things work. It seems like the Holley could be programmed so that the functionality of the CTAP isn't needed, but I'm unsure. Or is there a way to accomplish what I want to do without doing any of the above?
