HP Tuners what do I need
Old Dec 11, 2024 | 02:26 PM
Jd21476's Avatar
Default HP Tuners what do I need
I was going to send my car to a shop to have them plug into my computer and figure to why it is not starting. This means having it towed to the shop and then paying for hours of labor for diagnostic. I was also thinking of just buying the HP Tuners myself and doing it at home. From the website it looks like I need the MPVI3 to plug into my OBD2 port then download the software to my computer. Then it looks like I can download the current profile and if I want to make changes I have to buy credits but just looking at the program is free, except the cost of the MPVI3, correct?
Old Dec 11, 2024 | 04:37 PM
B52bombardier1's Avatar
Hello,
HP Tuners is expensive / complicated (but useful for many things) when a simple OBD2 Bluetooth module and a cell phone software app might be all that you need. I like the free Android "Car Scanner" app and a 15-20 dollar Konnwei or Nexas or OBD Link Bluetooth module that will display the 25-30 OBD2 parameters that are important to me. No "credits" required.
You can always step up to HP Tuners later.
Rick
Old Dec 11, 2024 | 04:52 PM
Jd21476's Avatar
Originally Posted by B52bombardier1
Hello,
Rick
I currently have a wireless OBD that runs to my phone but it wont tell me if VATS is disabled. Thats mainly what I am looking for
Old Jan 9, 2025 | 02:16 PM
Utinator's Avatar
Yes, that's basically it. When you buy HP Tuners, you get the OBD plug/cord, thumb drive, and a code to download the two software programs. Of course, you need a compatible computer to download to. You can buy credits to make changes if you want to, but it's not required for the Scanner program. You can use the Editor program, but you can't flash the tune file into the ECM without the credits. With the Editor program, you download the current tune in the car, then upload it here for us to help you out. The only time you have to buy credits is when you flash a file into the car's ECM. So, it really doesn't cost any credits to perform diagnostics.
Old Jan 11, 2025 | 05:15 PM
mrvedit's Avatar
Moderator
With the "411" PCM and likely some similar ones, if VATS is enabled the car will start just fine, but only run for about 1 second.
While HP Tuners can read codes, that is way overkill; downloading the tune is not going to tell you why you car won't start. Well, unless HP Tuners says it cannot even read you PCM, in which case it may be bricked or not connected correctly.
You just need to test for fuel and spark. (Assuming you have compression.)
Test for fuel pressure on the rail, if there, test injectors with a "Noid" light. If no light, check fuses for the injectors.
Test for spark. If no spark, check fuse for coils and/or check for +12V on the coils. If +12V to coils, but no spark, could be wiring problem, bad crank sensor or rarely things like bad PCM or broken reluctor wheel on crank.
